How Much Does Car Towing Cost in Malaysia? 2026 Pricing Guide
Your car dies on the road at 10pm, and the first tow truck you reach quotes RM400 for a 15 km ride. Is that fair? You have no way to tell, and standing on the roadside with your hazard lights on is a bad moment to negotiate.
Car towing cost in Malaysia usually lands between RM120 and RM500, depending on distance, vehicle type and who is paying. This guide walks you through typical rates, what pushes a quote up, and when your insurer covers the bill instead.
Key Takeaways
  • A standard car towed up to 10 km costs about RM120 in a published West Malaysia price guide, rising to RM250 at 50 km.
  • Private tow calls without insurance commonly cost RM150 to RM500 once distance and extras are added.
  • Flatbed trucks usually cost more than hook or wheel-lift trucks, but they are the safer pick for EVs, AWD cars and damaged vehicles.
  • Comprehensive insurance often includes free towing up to a limit, anywhere from 50 km to RM300 depending on the insurer.
  • Ask for an all-in quote covering distance, tolls and extras before the truck leaves.
Average Car Towing Cost in Malaysia in 2026
A standard car towed up to 50 km typically costs between RM120 and RM250. Add extras such as a basement pick-up or a longer route, and private call-outs without insurance commonly run RM150 to RM500.
The table below uses estimated charges from AA Singapore's West Malaysia roadside price guide, a published rate card for towing on the peninsula. Treat it as a benchmark, since the towing partner confirms the final price before work starts.
Towing Service
Estimated Charge (RM)
Notes
Up to 10 km
120
Pick-up point to destination
11 to 20 km
140
Standard car
21 to 30 km
160
Standard car
31 to 40 km
200
Standard car
41 to 50 km
250
Standard car
Beyond 50 km
4 per km
Long-distance rate
SUV above 2 tonnes
+60
Add-on
Basement or multistorey car park
+120
Add-on
Dolly, one set
+120
Front or rear wheels; two sets cost RM240
Highland towing
+250
Cameron Highlands, Genting Highlands, Kundasang and similar
Cancellation after 15 minutes
50
Charged once the truck has been activated
Rates also differ between operators and between peak and quiet hours. If you need a tow for your vehicle, you can easily book Driveo’s on-demand car towing service through the Driveo app!
What Affects Car Towing Charges
Five things move the price of a tow: distance, vehicle weight, where the car is stuck, timing and fuel costs. Knowing which ones apply to you makes it easier to spot a quote that does not add up.
1. Distance Travelled
Distance is the biggest driver. The guide above steps up from RM120 to RM250 across the first 50 km, then switches to RM4 per km.
Insurers that cap free towing usually charge RM3 to RM8 per km beyond the limit. Tolls on the route can land on your bill too, so ask whether they are included.
2. Vehicle Weight and Type
Heavier SUVs and MPVs may need bigger trucks, and the guide adds RM60 for any car above 2 tonnes. A flatbed may also be needed for certain cars, which we cover in the next section.
3. Where the Car Is Stuck
A tight basement bay adds RM120 in the guide, and highland roads add RM250. Cars wedged in drains or narrow lanes take extra time and equipment, so expect the quote to reflect that.
4. Time of Day and Waiting Time
There is no standard night rate across Malaysian operators, so after-hours or public holiday surcharges depend on who you call. Cancelling costs money too, with the guide charging RM50 once a truck has been activated for 15 minutes.
If you are stranded on a highway, our guide on what to do when your car breaks down on the highway covers the first steps before the truck arrives.
5. Fuel Prices
Tow trucks run on diesel, so fuel costs feed into quotes. In April 2026, the General Insurance Association of Malaysia (PIAM) said rising diesel-related costs had disrupted some towing services, causing delays and temporary suspensions in certain areas.
Flatbed vs Hook Tow Truck: Which One and What It Costs
A flatbed carries your whole car on its bed, while a hook or wheel-lift truck tows with two wheels on the road. Flatbeds cost more, and when you are unsure which your car needs, a flatbed is the safer call.
Flatbed Tow Trucks
The car is driven or winched onto a tilting platform, so all four wheels stay off the ground. That makes it the right choice for EVs, AWD cars, low-slung cars and anything with accident or drivetrain damage.
It also protects the car on long trips, since nothing is rolling on the road. The trade-off is a bigger truck and longer loading time, which is why it costs more.
Hook and Wheel-Lift Tow Trucks
These trucks lift the front or rear axle and tow the car on the other two wheels. They are quicker and cheaper, and they work well for short hops with a car that rolls freely.
The risk is to the wheels left on the road. Automatics, AWD systems and damaged drivetrains can all suffer, so check your owner's manual if you are unsure.
What the Price Difference Looks Like
Operators price the two methods differently, so there is no standard Malaysian markup to quote. Ask for the price with the method named, and tell the operator your car model, whether it is an EV or AWD, and whether the wheels turn.
The booking form for Driveo's towing service asks for your car model, plate number, vehicle location and destination, and it has a note field for details like a locked wheel or a low-clearance car.
Does Car Insurance Cover Towing in Malaysia?
Often yes, if you hold comprehensive cover, but only up to a limit. Accident towing is usually included, while breakdown towing and roadside assistance may need an add-on that typically costs RM20 to RM50 a year.
Call Your Insurer First
Most insurers want you to use their hotline so they can send an approved tow truck. If you call a private operator on your own, you may not get reimbursed.
PIAM noted in April 2026 that some insurers may reimburse independently arranged tows depending on policy terms. Confirm eligibility before you book, and keep every receipt.
Where You Still Pay Out of Pocket
Beyond the distance or cost limit, you pay per km. Free towing is also mostly tied to comprehensive policies, so a third-party policy may leave you covering the full bill.
If you are shopping for cover, you can request a car insurance quote through Driveo, which is currently in beta. Check the towing limit in any quote before you accept it.
When You Would Rather Skip the Claim
Driveo's roadside assistance services are open to any driver, with no insurance policy required and no claim to file. Driveo states that using the service does not affect your No Claim Discount (NCD).
Car Towing FAQs
Are There Night Rates for Car Towing in Malaysia?
There is no standard night rate across the country, so any surcharge depends on the operator. The AA price guide lists no separate night charge, but that does not guarantee yours will not add one. Ask for an all-in price before you confirm.
Is There a Cancellation Fee for Towing?
Often yes, if the truck is already on the way. The AA guide charges RM50 when you cancel more than 15 minutes after activation, and other operators set their own rules. Ask about the cancellation policy at booking.
How Much Does Long-Distance Towing Cost?
Past 50 km, the AA guide moves to RM4 per km, and insurers typically charge RM3 to RM8 per km beyond their free limit. For a long route, such as Kuala Lumpur to Johor Bahru, ask for a fixed quote that includes tolls, and request a flatbed.
Getting a Fair Tow Quote Before You Pay
Before you say yes to any tow, check your insurance limit first, then get an all-in quote with the distance, vehicle type and extras named. That one habit protects you from most of the surprises in car towing costs in Malaysia.
Not every breakdown needs a truck either. A flat battery, an empty tank or a punctured tyre can often be fixed where you are, through jump start, emergency fuel delivery, battery replacement or an on-site tyre change.
When the car does need to move, you can book Driveo's car towing service in Malaysia from the app in a few taps.
M
Mackyclyde
6 days ago
175
